WE HAVE PCI 7344 AND WE ARE USING AXIS CHANNEL 1 FOR PWM OUTPUT FREQYENCY . HERE I NEED TO CONTROL THE OUTOUT FREQUECNCY FROM 10 KHZ TO 1 MHZ STEPLESSLEY. ALSO I WANT TO VARY THE DUTY CYCLE OF THE OUTPUT PWM WAVEFORM from 10% to 100 % .
i have found vi in motion explorer where we can get the clock of 2 mhz , but the problem is that it does not get varied steplessly.
CAN SOMEBODY HELP ME IN GIVING THE VI WHICH WILL DO THIS JOB . THE PARAMETER OF CLOCK FREQUENCY AND DUTY CYCLE WILL BE GIVEN FORM THE CONTROLS OF LABVIEW.
ALSO CLARRIFY THAT IS IT POSSIBLE TO TAKE PWM PULSES FROM 10KZ UPTO 1 MZ ON DIGITAL I/O PORT OUTPUTS OF THE PCI 7344
REGARDS
SUDHIR SAWANT
CRUISER CONTROLS
