01-24-2006 11:28 AM
01-25-2006 09:28 AM
01-25-2006 12:05 PM
01-25-2006 12:22 PM
Thanks for the info,
the laser we use is a simple construction level laser (runs on 3 AA batteries usually) and draws 22mA, I like the idea of using a relay though and will do that. Thanks also for clearing up the configuration of the ports, now I'll tackle that.
Andre
01-26-2006 01:04 AM
02-24-2006 11:26 PM
02-25-2006 12:46 AM
It is possible to send analog output out of the same same DAC channel in which your stepper is connected, if you configure the stepper as open loop in MAX. I've tried it. This way you have the stepper output, analog output and encoder input acting independently. So you can use these seperately for different purposes, such as using the analog output for constant speed motors where speed or position control is not of much importance, encoder for positioning some other axes and stepper output for stepper control. With good programming skills, the NI motion controllers can thus be used for the most complex configurations. Great work NI !!! Nothing is impossible.
Giridhar Rajan
Automation Engineer, Design
Cruiser Controls
Mumbai, India
