epos 2
I am using LabVIEW to control EPOS2. I have the library functions. This program is working with my PC. Which means i can control all the EPOS2 in my PC.
However, when i transfer all my files into a laptop, the EPOS2 could not be controlled in LabVIEW through laptop.
It gives "error reading USB data. (0x23000002)"
Please advise..
Attached is the file and library
Message 1 of 9
(7,468 Views)
How are you connecting to the EPOS2?
With warm regards,
David D.
Message 2 of 9
(7,236 Views)
Thanks for Sharing
Message 3 of 9
(7,232 Views)
The issue have been solved with the new EPOS library function with the RED color initialize icon
Message 4 of 9
(7,188 Views)
I want to know how to connect the maxon motor's drive to the cRio?
Message 5 of 9
(7,127 Views)
Find the download and information on using it here:
https://www.ni.com/en/support/downloads/tools-network/download.epos2-positioning-controller-driver.h...
Best Regards,
Nate
Message 6 of 9
(7,122 Views)
THXs,I will try to do so
Message 7 of 9
(7,113 Views)
Do you use the laptop with the wireless?
Message 8 of 9
(7,099 Views)
I hope that you already solved the problem of "Reading USB data" from the epos2. If yes, would you please let me know how to solve this problem as I am receiving the same Error from the EPOS.
For your information, I am using linux (ubuntu) and the libEposCmd library from maxon.
Cheers
Message 9 of 9
(6,777 Views)
