daqmxbase 3.2 vi examples
I've installed NIKAL19.iso, NI-VISA-4.5.iso, nidaqmxbase-3.2.0.iso and finally LabVIEW8.6.1 in that order on Scientific Linux 5.2 which is essentially RHEL5.  Once I put the PCI controller in the correct slot and boot the machine with the PXI crate on, well, I'm floored to find out that
# lsdaq
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
NI 6221:     "Dev1"    (PXI15::15::INSTR)
Which is exactly what I wanted.  The next step seems to be to figure out how to use this device.  Best way is through examples, right?  They aren't there.  Oh sure, I have C API examples for daqmxbase, but nothing in LabVIEW examples or nidaqmxbase/examples.  Can't find anything to download on ni.com.  So, where are they?
Dan
(3,529 Views)
Run the DAQmx Base INSTALL script again. Since LabVIEW 8.6 was installed after Base, the script didn't know that you wanted any LV examples 😉
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(3,527 Views)
Thanks. That worked. Sorry this went to Motion Control and Motor Drives, cursor slip. Dan
(3,514 Views)
