Motion Control and Motor Drives
When using the analog inputs and analog outputs of the PCI-7344, what is the conversion between the voltage entering the card to counts? Similarly, what is the conversion between counts to voltage at the output of the card?
I am using the PCI-7344 to control my system. The analog inputs are connected to the output of my system while the analog outputs serve as feedback to the system. The system is a servo. I want to know what is the conversion between the voltage read at the input, to card counts, and finally to the voltage output to the system.
(3,640 Views)
Carole,
If you are trying to do analog feedback with a servo motor, Chapter 14 of the manual talks about how to set up the torque feedback.
Chapter 14
NI-Motion User Manual
A. Talley
(3,640 Views)
The 7344 has a 12 bit ADC per axis to use as analog feedback. This ADC can take +/-10 volts but can also be configured for 0-5, +/- 5, and 0-10 volts. Depending on the range the ADC is configured for, the value reported as position will be the binary digitized value for the analog signal (e.g. for a +/-10 volt range 20v/(2^12) = 0.0048828125 volts per count.)
(3,640 Views)
