Motion Control and Motor Drives
problem on control the bushless motors by motion assistant
I have used the MAX to control the motors sucessfully, but I cant use the motion assistant to control the motors. Any special setting or config. that I need to do?
(2,988 Views)
Are you initializing your board before running a move in Motion Assistant? Does Motion Assistant report any errors when trying to run these moves?
(2,988 Views)
