Motion Control and Motor Drives
What NI Stepper Drive is compatible with both NEMA 11 and NEMA 42 stepper motors?
I have a NI PXI-7350(Motion Controller), a NI UMI7774 (Universal Interface), and a NI P70530(Stepper Drive) and I tried linking up a new NEMA 11 stepper motor linear actuator from Hayden Kirk and kept getting a constant red blinking light on the driver. I then connected my new NEMA 23 stepper motor linear actuator from Hayden Kirk and the driver had the go ahead green light and it worked fine. I consulted the manuals and saw that the driver was only compatible for NEMA 17-34 Steppers. I tried the third party setting as well for the NEMA 11 to no avail. Does anyone know of a NI Stepper Drive that is compatible with my UMI and Motion Controller and also is compatible with a NEMA 11 and NEMA 42 (another motor I need controlled) stepper motors?????
(6,552 Views)
Accepted by topic author T.I.Line
Hello T.I.
It is true that our stepper drives have only been rated and tested for NEMA 17, 23, and 34 sized stepper motors. I personally have not seen or worked with drives with NEMA 11 or 42 stepper motors, but since NEMA standards are only a size standard, as long as your motors are within the voltage, current, and inductance specifications for your P7000 series stepper drive, then they should be able to work.
Huntington W
Applications Engineer
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
(6,521 Views)
Thank you for the quick response
So I have connected as the Third Party Motor option with the P70530 Stepper Driver. I have read the manual and selected the appropriate DIP switches for the third party motor setting. As instructed I downloaded the P7000 Tools 2.11 to set up the motor with the driver. When I open it and try to search for the driver nothing is located. I have appropriately changed the COM settings in the device manager to the appropriate values and also I am seeing the steady green light on the driver. I am at another stand still. What else can I do to get the driver recognized so I can set up these motors?
Thank you for your time,
Tom
(6,480 Views)
