Motion Control and Motor Drives
Warning while loading example VIs for XPS motion controller
I'm new to Labview. I want to control the XPS motion controller using Labview and I wanted to get started with the examples provided by XPS along with the drivers. But I get a warning while loading the example. I have attached a screenshot of it. Please help.
Also, opening the example opens just the front panel. How do I open the bloack diagram of the example VI?
Thank you.
(5,520 Views)
That warning is nothing to be worried about -- it just means that things were found in a new location, which is normal when you move code around.  Once you save the project it should go away.
To look at the block diagram, use Window - Show Block Diagram, or simply Ctrl+E.
Good luck!
Edwin
(5,505 Views)
