I'm interested in knowing the concepts / formulas / algorithms invovled in circular interpolation. Suppose I give the position where the I have to reach in a 2-D plane and the radius of the circular arc, then the controller feeds the X-axis drive with a sequence of position commands which follow a mathematical function and at the same time, the controller also feeds another set of position commands to Y-axis, which follow another mathematical function. Also the velocities of X-axis and Y-axis follow two seperate mathematical functions. The combination of all these mathematical functions executed simultanously results in an interpolation. This is my understanding of circular interpolation. I am interested in knowing these four functions for X position, Y-position, X-Velocity and Y-Velocity. Kindly help me out with this. Kindly let me know if my understanding of the concept is wrong and what may be right approach to this problem. I do not want to use the arc vi provided by NI as it takes 'start angle', 'travel angle' and 'radius', but I want to feed 'start position', 'final position' and 'radius' to achieve th arc.
Giridhar Rajan
Automation Engineer
Cruiser Controls
Mumbai, India
