Motion Control and Motor Drives
USS protocol library
kudos
can i get uss 1.2 in lv 8.2
thx
J
Message 51 of 64
(2,649 Views)
Hi!
I'm using a 6SE7011 driver connected to a 1FK7 motor. I am trying the following to connect to it, although it does not work.
What sort of cable did you use? Was it the commom RS232 cable?
I apreciate the help, thank!
Message 52 of 64
(2,614 Views)
Hi Dservo
I assume you have troubles with the PKW and PZD areas in your telegram. Take a look at the following documentation from Siemens and change accordingly on your inverter so you can change Integer or float parameters in EEPROM or RAM.
http://support.automation.siemens.com/WW/view/en/5​734889
If the previous document was not good enough, here you have a more comprenhensive explanation of the USS protocol:
http://support.automation.siemens.com/WW/view/en/2​4178253
Message 53 of 64
(2,607 Views)
THanks Parga,..
Still having some issues thou,.. It seems that PKW does not like to modify,... reads OK but when I switch to modify no go,.. Any other thoughts would be helpful,.
J
Message 54 of 64
(2,593 Views)
I used to have same kind of troubles. The issue was that I was trying to modify a parameter that isdefinded as Int16 and I was trying to write a float on the parameter.
It helped me a lot to handbuild my telegram and then send it via a Serial terminal (here you have a good one: http://www.opend.co.za/software/terminal/index.htm). Maybe that could help you.
Message 55 of 64
(2,584 Views)
I am working on a project. I want to connect 6RA70 with Labview. Do u know anything about it. Basically, I want to run it completly through Labview. And the Drive would run the motor on the given formula, and automatically take input from drive on the basis of formula
Pl. help
Message 56 of 64
(2,429 Views)
Hello Vijay2004,
I would kindly ask you for opening a new thread regarding your particular issue. I recommend you also to specify what is your goal (controlling Siemens drive from LabVIEW?) and perhaps what issues are you getting into.
Thank you!
Jakub Prokeš
NIEE Aplications Engineer
Message 57 of 64
(2,415 Views)
I have already connected 6RA70 with Drive Monitor but I am unable to connect it with LabVIEW.
Any Help?
Thank U!
Message 58 of 64
(2,397 Views)
Please can you specify what troubles are you encountering? What do you mean by "having connected to Drive Monitor"?
Jakub Prokeš
Message 59 of 64
(2,368 Views)
Can u tell me how to connect simoreg 6RA70 with LabVIEW using USS protocol library. Can u tell me what are the codes.
Is some hardware needed to connect it with?
But, where would I get USS protocol library?
Pl. Help
Thanx!
Message 60 of 64
(2,361 Views)
