Motion Control and Motor Drives
TBX-68 and PCI-7344 Digital I/O Connector
Is it possible to use this combination and what shielded cables are recommended?
Thank you.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(6,486 Views)
Accepted by topic author RVallieu
The TBX-68 uses the same 68-pin .050 Series D-type female connector as the UMI-7764.  So any of the NI SH68-C68-S cables will connect to the TBX-68 and the 68-pin VHDCI offset male connector on the 7344.  The NI recommended cable is the 0.5m listed under part number 186380-0R5.
Chris L
Applications Engineer
Certified LabVIEW Associate Developer
(6,481 Views)
