le 10-30-2007 09:29 PM
le 10-31-2007 03:30 AM
le 10-31-2007 04:32 AM
le 10-31-2007 04:47 AM
le 10-31-2007 04:51 AM
le 10-31-2007 12:33 PM
le 10-31-2007 08:21 PM
le 11-01-2007 04:26 AM
le 11-01-2007 10:21 AM
I wonder if you have some gear lash issues that are unidirectional. Can you test the motor in both directions when disconnected from the gear train?
Another test is to provide a stable frequency from a function generator to control speed and just use a voltage source to control direction. This would eliminate the use of your program and DAQ card as a test to see if it a problem with the motor and gears.
le 11-01-2007 07:41 PM
