PCI-7324/MID-7604 Support
Hi all,
It would appear that the PCI-7324 card that I purchased on eBay (but has not yet arrived) is incompatible with Windows 7/Motion 15.0/LV 2015.. is that correct? https://www.ni.com/en/support/documentation/compatibility/17/ni-motion-controllers-and-microsoft-win...
In this case, can I assume it's completely useless to me?  What about the MID-7604 driver I purchased.. that can still be used with the newer PCI-7334, correct?
Thanks and Merry Christmas/Happy Holidays!
(5,032 Views)
Hi joegreene, I think you are right.
It looks like NI-Motion 15.0 doesn't officially support PCI-7324...
PCI-7324 is only supported by ValueMotion driver
Why you have bought this one....?
Certified LabVIEW Developer
GCentral
(5,019 Views)
Because I first came upon this document which promised support for "73xx" controllers, and the 7324 fits that profile? https://www.ni.com/docs/en-US/bundle/373329e/resource/373329e.pdf
Assuming a PCI-7344 will be fine?  (Found for $300 vs $500 on the 7334).
Thanks.
(5,007 Views)
Before purchasing these devices, I think you need to contact NI.
They can give you the technical suggestion.
But I think NI-Motion doesn't support PCI-7324....
I am sorry that I was unable to be of any assistance...
GCentral
(4,985 Views)
Hi tepig,
You have been of assistance and it's greatly appreciated!
I do have a contact at NI so yes I should have asked before ordering-- that said the 7324 was only $60, so I'm not out as much as one may expect!
The 7324 actually came yesterday.. I was thinking of popping it in, but any trouble I encounter would likely be a result of the card, thus it's more trouble than it's worth!
(4,978 Views)
ummm.....
On the other thread, Jochen said
The best option would be to contact your local NI branch for a hardware upgrade to a PCI-7334
which is the drop-in replacement (form, fit and function) for the PCI-7324.
https://forums.ni.com/t5/Motion-Control-and-Motor-Drives/pci-7324/td-p/279124
GCentral
(4,951 Views)
Good point, however that thread is also talking about still using ValueMotion VIs and far older LV.
What do you mean by the "other thread"?
(BTW, can't figure out my login so at work this I post from "joegreene" and here "visionmotion"... I'll figure it out when the motivation arises!)
(4,944 Views)
