01-17-2008 10:49 AM
01-18-2008 01:38 AM
01-18-2008 09:56 AM
Hi Jochen,
Thanks for your response. NI-Motion does leave me with Measurement and Automation Exploerer 2.2.0, but it overwrites FlexMotion 5.1.5 I reinstalled LabView followed by NI-Motion 5.2, and then I installed the 7344 board. I then updated the firmware using MAX. I can get the motor to run when I use the "Home" vi but when I go to use my main program vi it gives me multiple "you have connected two terminals of different type" errors.
Gary
01-21-2008 09:21 AM
Hi Gary,
NI-Motion 5.2 is an update to FlexMotion 5.1.5 so it will overwrite the previous driver. Based on the errors you are getting, I will bet that some of the VIs in your program have changed between FlexMotion and NI-Motion. You can take a look at the block diagram and pretty easily spot the VIs that have changed and many times it is pretty intuitive to know which NI-Motion VI to use in replacement.
01-21-2008 11:27 AM
