03-28-2011 03:30 PM
Dear all
Now we want to control a stepper motor with voltage ratings up to 110 V and 0.5 A at 110 V
we have the 2 Axis PCI-7342 motion controller and the NI UMI-7772 Terminal block for third party motor drives
please advice , what is the suitable third-party stepper drive that can fullfill the above ratings and compatible with the UMI-7772 ??
i have found only one link for a company called ParkerMotion (check this link : http://www.parkermotion.com/literature/pdf/aries.pdf ) but I'm not sure if it is compatible with the UMI-7772 or not
waiting your replies and thanks in advance
03-29-2011
10:19 AM
- last edited on
06-30-2024
05:30 PM
by
Content Cleaner
Hey Mohammed,
Here is a link to our Drive Advisor. There are stepper motors that we suggest at the bottom and it also tells you whether or not a UMI is required.
I hope this helps.
Ricky V.
03-30-2011 06:18 AM
Almost any standard stepper or servo drive would be compatable with a UMI. The Parker Aries you have a link to is a servo drive, not a stepper drive. You motor ratings are unusual for a stepper motor. What is the brand and model? I have had good luck with Applied Motion stepper products. www.applied-motion.com
