Motion Control and Motor Drives
NI UMI-7772 and third party Stepper Drives
Dear all
Now we want to control a stepper motor with voltage ratings up to 110 V and 0.5 A at 110 V
we have the 2 Axis PCI-7342 motion controller and the NI UMI-7772 Terminal block for third party motor drives
please advice , what is the suitable third-party stepper drive that can fullfill the above ratings and compatible with the UMI-7772 ??
i have found only one link for a company called ParkerMotion (check this link : http://www.parkermotion.com/literature/pdf/aries.pdf ) but I'm not sure if it is compatible with the UMI-7772 or not
waiting your replies and thanks in advance
Eng. Mohammed Ashraf
Certified LabVIEW Associated Developer
InnoVision Systems Founder, RF Test Development Engineer
www.ivsystems-eg.com
(4,801 Views)
Hey Mohammed,
Here is a link to our Drive Advisor. There are stepper motors that we suggest at the bottom and it also tells you whether or not a UMI is required.
I hope this helps.
Ricky V.
Applications Engineer
(4,790 Views)
Almost any standard stepper or servo drive would be compatable with a UMI.  The Parker Aries you have a link to is a servo drive, not a stepper drive.  You motor ratings are unusual for a stepper motor.  What is the brand and model?  I have had good luck with Applied Motion stepper products.  www.applied-motion.com
(4,781 Views)
