Motion Control and Motor Drives
NI PCI-7332 Linux drivers
I am looking for options to interface with NI PCI-7332 from g++ LInux. I found links to SystemSynergy drivers, but they do not seems to support Linux anymore.
Does Linux support exists? If there isn't Linux support, I can code Linux driver myself, if I will get access to hardware description documents (I am familiar with PCI bus operations and Linux drivers issues).
With best regards
Petr Kubánek
Institute of Physics, Academy of Sciences Czech Republic
(5,556 Views)
Hi Petr,
The NI-Motion drivers are not support Linux, and I am not sure SystemSynergy has to offer. Actually there is a similar post on our discussion forum where you can see the same message and you'll find links to the Motion driver developer's kit.
Check out the other thread here.
I hope this helps
Barna D.
(5,537 Views)
Hi Barna,
thank you very much for reply. I think I understand how to write a driver using this informations. However the DDK link in Functions/DDK Commands and Packets to DDK-Commands.html file, which I cannot find in the DDK zip file. Is there any way how I can retrieve it?
Best regards
Petr Kubánek
(5,529 Views)
Accepted by pkubanek
Hi Petr,
I am not quite sure to understand your question. I downloaded the Motion DDK for myself and I managed to open the help file and it seems that all the links work in the help file, as you can see in attached picture.
Could you explain me more what was not working for you?
Barna
(5,521 Views)
Sorry for bothering yout, that turned out as problem in Linux chm reader I am using. It works as expected under Windows.
(5,513 Views)
Hi Petr,
No problem, I am glad that you can read the help file now. As you probably noticed Motion driver development is supported by NI R&D trough NI Sales team, so feel free to contact NI Czech team directly for further support.
Best Regards,
Barna
(5,501 Views)
