‎02-01-2006 11:07 AM
‎02-02-2006
06:05 PM
- last edited on
‎11-11-2025
12:15 PM
by
Content Cleaner
Hi Sadiah,
Below are some links that may be helpful to you:
PID Theory Explained
https://www.ni.com/en/shop/labview/pid-theory-explained.html
‎02-03-2006
02:12 AM
- last edited on
‎11-11-2025
12:16 PM
by
Content Cleaner
Sadiah,
please note that FieldPoint is much slower than a PCI-7344. While the 7344 can run PID cycles with up to 16 kHz FieldPoint will perform PID loops with about 100 Hz. To research general control behavior this might be ok but if you want to use FieldPoint in a real-world application you should figure out if the PID loop is fast enough for you.
If you need faster PID loop rates with the same or even more flexibility than FieldPoint please have a look at our compact RIO products.
Bes regards,
Jochen Klier
National Instruments Germany
‎05-10-2007 06:36 AM
Dear Joachen,
I have been trying to run my servomotor system+load using softmotion. The motor runs but jerking. I check the program available for motion loop but could not figure out the problem. Is this also being the reason why I am not getting the transfer function when determining the system identification.
TQ
SADIAH
‎05-11-2007 02:32 PM
‎05-12-2007 06:32 AM
Another from me regarding the system identification of the plant. I did the open loop test, and the results were excellence. But when it come to system identification phase, adjusting the model does not bring out good comaprison between simulated and plot values.
What are the best model for my plant; should it be state space, ARX, ARMAX etc. Need suggestion frm whomever hasexperience with system identification.
TQ.
SADIAH
