Motion Control and Motor Drives
Motion Control Program VI
Currently I have a LabView VI to control an XY Positioning System with two stepper motors and Unislide assembly using MD125 micro-step driver and NI PCIe - 6321 Multifunction DAQ device. I need to modify the VI in order to make the slide move from one position to another. I am using 10 micro-step resolution in the driver and selecting 300 RPM from the VI. Can I get some help in modifying the VI.
Bharath J S
(4,616 Views)
The slide moves by 0.42 inches for one click of the direction key.
Bharath J S
(4,612 Views)
Is there a particular task you're having trouble with?  Or are you just trying to get started?  This forum will be more helpful for you if you can post specific questions or tasks you need help with.
Cody A.
(4,574 Views)
