01-24-2012 11:56 AM
Hi CKH,
To remove motion, you will need to go to your computer's Control Panel > Programs and Features > National Instruments Software, and then find NI-Motion in the list to remove it.
Here is NI-Motion 8.3, but make sure that your version of LabVIEW supports it in the previous link I posted.
Best Regards,
Nathan B
01-24-2012 03:55 PM
Hi Nato3,
I was reading the other post, it said this could be because I put the PCI-7340 first before I install NI-motion 8.3. Could this be the problem? If so, do I have to do all the remove NI-motion and remove the PCI then install NI-motion, conncect PCI again? I post an image in my previous post, showing the PCI-7340 actually showed up.
01-25-2012 10:43 AM
Hi CKH,
Yes, that is correct, and when you reinstall make sure you are using the correct version of NI-Motion. 8.3 only works with LabVIEW 2011.
Even though it was able to see your card, something must have gone wrong because the examples and motion VIs should have shown up also.
Best Regards,
Nathan B
01-25-2012 11:04 AM
Hi Nato3,
I'm sure I installed 8.3. So, If i reinstall everything in the correct order, the vi example will show up for sure?
Thank you
01-26-2012 09:54 AM
Hi CKH,
They should, and reinstalling the software and card in the correct order would be my first method of fixing it.
If that does not work try following this KnowledgeBase article. Let me know how that works, and if it is not successful then we can keep troubleshooting.
Best Regards,
Nathan B
01-26-2012 02:33 PM
Hi Nato3,
I got all figured it out, I actually need to use Labview 32-bit instead of 64-bit, I changed it and reinstall everything in the correct order, everything is working now. Thanks for all the help.
Thank you,
CKH
