01-23-2012 09:18 AM
I am a labView novice so any advice would be greatly apprecialted. I am needing to write a VI to to control a stepper motor. I would like the motor to move to a position selected by the user. Down the road I would like it to do more but I need to crawl before I walk. I am using an old Velmex NF90 series stepper motor controller. I also have a VEXTA stepper motor.
I have the velmex manual which lists the controller commands but I have having difficulties in how the commands will be implicated into the VI.
Any advice or links would be greatly appreciated. I have tried searching or help on the topic but I might of missed something. Thanks
01-24-2012 12:48 PM
How are you communicating with your motor controller? Are you using the third-party drivers found on our website for the Velmex NF90?
If you're communicating with it through serial, you will want to check on using NI-VISA, the NI software that establishes serial communication.
01-24-2012 03:55 PM
I have a NI USB 6008 DAQ. I can't use the old drivers for the NF90 because the version of labview (of the drivers) isn't compatable with the version i'm using.
01-25-2012 02:20 PM
this is a basic program i wrote for my stepper control it should work for your needs too
01-25-2012 02:57 PM
You have a newer version than I do (10.0.1). Can you either convert the VI to an older version or post a couple JPEGs? Thanks
01-25-2012 04:10 PM
This should work.
01-26-2012 03:49 PM
let me know how you get on, lm working on 2d array at the moment so i can control four stepper motor at a time with pulses
