Motion Control and Motor Drives
How to tackle Forward limit active without stop running vi
how to tackle Forward limit active without stop running vi: Our robot is comprise of with 8 joint,to limit the robot work area we use the limit botton But now the problem is whenever the limit button is active the vi will stop. i had decompose the errot clust.But i doesnot work ,Is there any good method to solve this problem Thanks!!
(3,635 Views)
Please provide more information about the hard- and software you are using:
- NI-Motion board type
- NI-Motion software version
- LabVIEW version
- Simple example code that reproduces the problem
Jochen Klier
Applications Engineering Group Leader
National Instruments Germany GmbH
(3,635 Views)
Thanks for your answers.
the motion card is flexmotion 7344 card and driver is motion 6.0, lv 7.0
simple example is the " continue buffer motion"example can down from the ftp.ni.com.
waiting your answer
(3,635 Views)
Are you talking about the SHM_continuous.vi? This vi will stop whenever an error occurrs. Anyway - you should always react in your software on events like hitting a limit switch. You should use the "Read per Axis Status.flx" vi to find out that a limit switch was hit.
Jochen
(3,635 Views)
My programme is not the same as this one but equal mostly.As u know this programme is while loop with high speed.I consider thought i react in software the loop must stop,but that is not allow in my system.
moreover plus too nod in while loop will reduce the loop speed.Is there anyother method i can try?
thanks!
(3,635 Views)
