Motion Control and Motor Drives
High Speed Encoder capture offset
My high speed encoder capture data intermittently contains an offset that seems to be 2^16. This offset persists in subsequent data. It appears that the counter is being incorrectly incremented by this value. What could be causing this?
(2,930 Views)
As our support databases don't report such a behavior this sounds like an individual hardware problem of your board (looks like a bit is toggling).
Just to rule out other possibilities please make sure that you have installed the latest NI-Motion software and firmware which is version 6.1.2.
Here is the download link:
http://digital.ni.com/softlib.nsf/websearch/57FA88D0FEC8439F86256C740024CE88?opendocument&node=132060_US
For the case that you have already installed installed the latest driver and the problem persists please contact your local NI branch for a board exchange.
Jochen Klier
Applications Engineering Group Leader
National Instruments Germany GmbH
(2,930 Views)
