Motion Control and Motor Drives
How to implement direct communication between two singleRio boards by using Ethernet?
Now in my project we choose 2 SingleRio-9032s as our controllers. We need the two controller can be exchanged data directly by using Ethrenet ?How can I do ?
(6,123 Views)
Accepted by topic author yuefeiw
yuefiew,
This discussion probably belongs in the LabVIEW RT forum.
However, I would suggest looking into LabVIEW Shared Variables.  The two links below will give you more information on the topic:
http://zone.ni.com/devzone/cda/tut/p/id/4679
http://zone.ni.com/devzone/cda/tut/p/id/9900
Kind Regards,
Drew T.
Camber Ridge, LLC.
(6,113 Views)
OK,thanks a lot . Net published shared variable may be a good choice. But I am not sure the delay caused by this method can meet our requirement.My sampling time is 50us. I will ask for help in Labview RT. thank you for your guidance.
Yuefei
(6,109 Views)
Yuefei,
The following link is a good guide on finding a networking protocol to suit your needs.
http://zone.ni.com/devzone/cda/tut/p/id/12079
See you over in the RT forums!
Drew T.
Camber Ridge, LLC.
(6,098 Views)
