Motion Control and Motor Drives
Help: Stepper motor control with NI9401 and CompactRIO 9039
I want to generate the square waves to contorl the stepper motor through NI9401. And I have writen a simple FPGA code to generate the square waves as shown in Figure.
But now I want to generate finite steps for my stepper motor to move? How to do it?
Thanks very much!
English is my second language, sorry for my poor writting skills.
(3,615 Views)
useful links and documents
https://www.ni.com/en-us/innovations/white-papers/16/motion-control-with-compactrio--the-ultimate-multipurpose-contro.html
https://www.ni.com/docs/en-US/bundle/373871a/resource/373871a.pdf
with this you should be able to do what you want
bhovhann
(3,545 Views)
Thanks for your reply. I have read the document in the above website. But, it seems like that all control way is using the NI 95xx C serial modular. Unfortunately, we don't have this modular.
We have a stepper motor controller, but it need square waves signal to control the rotation speed and direction of stepper motor.
Now, we only want to generate a square waves signal  through NI9401 to control the stepper motor.
I have written a simple code to generate square waves, but it cannot adjust the frequence of square waves at real time and generate finite square waves. So, could you give me some advices and some references?
Thank you very much!
(3,531 Views)
Accepted by Tianci
Here you can see part of the FPGA and Part of the host. you should know that using only FPGA you can't regulate parameters in real time. For that you should use RT or HOST or both of them. For example, you can also go through this link https://forums.ni.com/t5/Example-Programs/Generate-PWM-signals-on-cRIO-analog-output-module/ta-p/351...
bhovhann
(3,517 Views)
Thanks for your reply. It is very useful.
(3,480 Views)
