Does UMI-7774 need power source?
This may seem like an obvious question, but I need to ask it anyway:
I am using the PCI-7334 and UMI-7774 to control my E-DC drive and step motor. Does the UMI needs any power? For now, the UMI is plugged to the PCI-7334 and the step motor and power source are plugged to the E-DC drive which is plugged to the UMI.
Please help me!!
(3,925 Views)
Yes, the manual states that you need at least one 24VDC power supply.
(3,921 Views)
Can I use the same power source I am using for my step motor (24 VDC - 5 A output)?
(3,918 Views)
I would not.  You should have an unregulated power source for the steppers, and a regulated source for the UMI.
(3,914 Views)
What do you mean by regulated and unregulated?
(3,913 Views)
A regulated power supply will hold its rated voltage.  An unregulated one will not.  Stepper drives typically don't get along with regulated power supplies because at start up there is a larger current draw.  The power supply may think this is a short-circuit and either foldback or trip.  Regulated supplies are also more expensive.
(3,908 Views)
