Ni.com is currently experiencing issues that may cause some pages to fail.
Support teams are actively working on the resolution.
Digital I/O the last step before I FINISH!!!
Digital io... Im at the final step in creating my program.  I have created a program inteded to automate the cleaning process of an atmospheric chamber.  My program is intended to iniatate the fill and evacuation valves based on the pressure readings.  I know the card I am trying to comunicate with is the NI PCI-6023E. I was told that the first four channels are already being used.  i will be working with channels 5, 6, and 7. It was also mentioned to me that in order to comunicate with only channel 5,6, and 7 i must create a mask. I have taken a look at previous programs and they all use port config, port write and port read.  I am also confused at the cluster of true and false constants which seem to have to do with masking the bits... I hope somebody can help
(3,319 Views)
You may want to post this in the Multifunction DAQ forum, since your application doesn't involve motion control.  You will probably get an answer there.
(3,292 Views)
Hi overmyhead,
I understand that you are trying to write to only certain lines in your port, using a line mask. To do this, you will simply want to specify a value for the "line mask" input of the DIO Port Write VI. This input is an I32 value; thus you can simply input a value of "224" which would represent the value "11100000" in binary (bits 5, 6, and 7 are set to '1' to indicate that these lines will be written to). I am not sure what cluster you are referring to. Many times, a cluster or array of boolean values is used to represent bits, and this cluster or array is then converted to an integer value.
For an example of writing values to a single line within a port, please refer to the LabVIEW Example Finder (under Help » Find Examples). Within the Example Finder, if you choose to browse according to directory structure, you can find this example under "daq » digital » E-series.llb » Write 1 Pt to Dig Line (E).vi". While this example may not be exactly the same as what you are trying to do, it gives a good idea of how the DIO Port functions are used. I hope this helps,
Daniel S.
(3,290 Views)
