Cable options for UMI to OPTO-22 G4 I/O Module
I currently have an OPTO-22 G4 8-Channel Rack with a standard 50 pin header. My current motion controler just has a ribbon cable that connects to this I/O board. I am replaceing the controller with a PCI7332 and UMI7772. I need to get the G4 board hooked up to either the PCI7332 or the UMI7772. I purchased the SH6850 cable to go from the PCI7332 directly to the G4 board but I need the SHC68 to 50 pin instead.
Is there a cable to go directly from the PCI7332 to the OPTO-22 G4 rack?
If not is there a cable to go from the UMI-7772 to the OPTO-22 G4 rack?
(3,856 Views)
Hello Viper,
Unfortunately there is not direct way to connect our motion hardware with your current Opto-G4 Rack.
You can see a knowledge base article about motion cabling here:
http://digital.ni.com/public.nsf/allkb/5BCA4D4A31025542862573BF0057750A
Essentially, the PCI 7332 has a 68pin output that can connect directly to our Motion drivers or UMI's using the SHC68-C68-S cable
The other cabling option is the SH68-C68-S that has one of our VHDCI connectors on one end and a 0.05 68-pin SCSI D-type connector on the other that can be used to interface with some 3rd party devices.
The UMI is just a breakout box that has 68 screw terminals that map to the 68 pins output from the PCI card.  You can also make a custom cable.  We offer the SHC68-NT-S Shielded Cable Assembly (unterminated) which has our 68pin connector on one end, and open ended wires on the other which you can put your own connector on.
Hope this helps!
Rishi L
Applications Engineer
(3,838 Views)
