 MrSteve
			MrSteve
			11-02-2009 08:16 PM
Hi everyone, I'm seeing some bizarre behavior on my system and was hoping you could help me out.
I have the PCI-7334 stepper controller installed and running on my system, with 2 axis-s connected.
Axis 1 operates as expected, running one direction for a positive target, and the other for a negative target.
Axis 2 on the other hand, runs in the same direction regardless of if I give it a positive or negaative target position.
This seems to be limited to axis 2, I connected the wires running from axis 1 on the connector block to the second motor driver and it then started to act as expected.
Any idea whats going on?
11-03-2009 03:17 AM
Have you checked with a DMM or a scope if the Dir output is working fine? Maybe this behavior is caused by the wiring of the open collector outputs for step & direction. Maybe due to device tolerances the current driven by axis 2 for the Dir output is a little bit too low, so the drive doesn't recognize the changed level. Please refer to this link in our KB and check if the wiring hints apply to your setup.
A second option is a defective board. In this case please contact your local NI branch.
Jochen
