05-01-2006 09:36 AM
05-02-2006
02:18 PM
- last edited on
11-23-2025
06:31 PM
by
Content Cleaner
Mic_Scale,
I believe the document below will help you get off to a good start...
http://zone.ni.com/devzone/conceptd.nsf/webmain/544693068FB4893186256E75006C84AA
If you could be a bit more specific regarding both your system and what you want to know, I might be able to help you out more. What type of data is coming from the chip (how is it formatted) how is that data sent to your LabVIEW system. Describe the 3 points in more detail. Overall, if you could provide a very detailed explaination of what you are doing I can do a better job of answering any questions.
Lorne Hengst
Application Engineer
05-04-2006 12:16 AM
05-04-2006 06:27 PM
Mic_Scale,
Do you already have the hardware you are going to use for the system? or are you looking to spec out a new system?
If you are using a firewire camera, a cameralink camera, or an analog camera, you can use a National Instruments products bring your image into LabVIEW and then use NI Vision 8.0 to calibrate the image to match your map. You would need to detect 4 objects in your image and know the x,y position of these points in inches, yards, feet, etc. Then, the IMAQ Vision calibration VIs can convert the pixel locations of the image to the real world values. Once this is done you can pick any point on the image and find its corresponding real world value.
This should accomplish what you want, but instead of 3 points you will need 4 points.
Tell me what you think.
Lorne Hengst
02-20-2009 04:19 PM
What you are talking about, way back in 2006, is a basis transform, or a coordinate transform. Computer graphics systems do this kind of thing all the time so there is a lot of literature on how to do it.
In particular you are doing a rotation transform, a translation transform and a scaling transform.
Each transform can be represented by a matrix equation. X'=A*X where X' is the transformed coordinate, A is the square matrix representing the transform, and X is the original coordinate. (So X might be the map coordinate while X' might be the stage coordinate.)
The trick for you is to calculate the several factors you need to create the A matrix. In your case this is Xo, Yo, Theta, and S. Xo and Yo represents the translation from one coordinate system to the other. So if you picked up the X and Y axis and moved it without rotating or changing scale, what would the distance be from the X origin to the X' origin. Theta is the amount the coordinates system rotated. S is the amount the coordinate system scaled.
One of the gotcha's here is if the coordinate system has inverted axis from each other. If the map has positive X going right and the stage has positive X going left you have to have a negative in the matrix to account for this.
The values you need can be calculated by using non-linear system of equations techniques. I use the Levenberg-Marquart library in NI LabVIEW.
X'=Sx*(X*cos(Theta)-Y*sin(Theta)+Xo)
Y'=Sy*(X*sin(Theta)+Y*cos(Theta)+Yo)
3 points gives you six equations with 5 unknowns. Because of the sin(Theta) and cos(Theta) terms, the equations are non-linear.
Once you have the 5 unknowns (Sx, Sy, Theta, Xo, and Yo) you can use the equations above to transform any point.
http://en.wikipedia.org/wiki/Coordinate_rotation
http://en.wikipedia.org/wiki/Change_of_basis
http://en.wikipedia.org/wiki/Transformation_matrix
Take special note of Afine Transformations. This is how the graphics guys do it.
