Motion Control and Motor Drives
该买哪种控制卡
大家好
我们实验室有个双杆注射计量泵,已坏,通电发出指令后两个步进电机没反应,没通电时,可以手动转动步进电机,通电后转不动。整个泵的加压系统如下 网址所示,
http://www.isco.com/meteringpump/default.asp
此泵两个活塞杆上原来有两个压力/强传感器,反馈给控制器组成个闭环控制系统,正常情况下能精确控制压力和流量。
电机的驱动说明如下
http://www.compumotor.com/manuals/drives/RDrive.pdf
http://www.compumotor.com/manuals/drives/MDrive.pdf
假设驱动和电机都没坏,该买哪种控制卡好呢?
请教高手了,
谢谢
(4,825 Views)
Hello yaha,
Would you mind putting your post in English?  This would allow me to better assist you.
Lynn
Senior Systems Engineer
(4,810 Views)
Hi Lynn
Thank you for your reply, I have posted another thread (same topic) in English, it is about two stepper motors in a dual cylinder syringe pump.
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/which-motion-control-card-is-good-for-this-s...
you can delete this thread in Chinese if you can.
I appreciate your attention and help.
Best Regard
(4,803 Views)
Hi yaha,
I see Paul has helped you. Let us know if you have any further questions.
Lynn
(4,793 Views)
