Measurement Studio for VC++
unable to drag instrumenten-I/O assistant into the block diagram in labview 2009
When I try to drag instrument I/O assistant into the block diagram I receive an error message " Measurment Explorer or Instrument I/O Assistant not installed correctely. Please install these ftom the LabVIEW Driver CD."  I have LabVIEW 2009 9.0f2 (32bit) installed and Measurment & Automation Ver 4.6.0f1
(6,117 Views)
Hi
 First make sure that you have installed the following drivers:
- NI-VISA
- NI-488.2 this is necessary only if you are using GPIB
Both of these drivers are available for download on the National Instruments website.NI-VISA  and NI-488.2
After these drivers are installed, you should uninstall and reinstall
the Instrument I/O Assistant from the Device Driver CD.  If you do not
have the Device Driver CD you can download it from our website.  Make
sure the Instrument I/O assistant is selected when you install the
drivers, as shown in the attached zip file.
regards
Houssam
NI Germany
(6,097 Views)
