Measurement Studio for VC++
cannot open tdms file
Hi Pery S,
Thanks for your replay.
I create the TDMS file while recording the data
DAQmxConfigureLogging(taskHandle, logFile.toAscii().constData() ,DAQmx_Val_LogAndRead,"GroupName",DAQmx_Val_OpenOrCreate)
Then when I try to open it I got the 6210  error.
Here link to TDMStesting example
http://forums.ni.com/t5/LabWindows-CVI/TDMS-DLL/td-p/792269
Message 11 of 14
(4,532 Views)
Hi Simon27,
I have tested the file that you created and it opened successfully in two out of the three environments that I used. I was able to open it in DIAdem and Visual Studio 2010 (Using a cs Measurement Studio example). When I tried using LabWindows CVI, which is a c development environment I ran into some runtime errors. The errors told me that some properties were not correctly defined. I am looking more into it. I will let you know what I find.
Perry S.
Applications Engineer
Message 12 of 14
(4,515 Views)
Thanks!!
Message 13 of 14
(4,512 Views)
Accepted by topic author simon27
I solved it by using the "Dominonilibddc" libary.
I found it at http://forums.ni.com/t5/Measurement-Studio-for-VC/TDMS-read-error-getdatatype/m-p/1584692#M7241
And I copied the Data Models folder with the dll files to the build folder of my project and it solved it.
Perry S. thanks alot for your guidance!!
Message 14 of 14
(4,510 Views)
