Measurement Studio for VC++
call DAQmxRegisterEveryNSamplesEvent in managed code
Ciao to all,
I'm integrating the example Cont Acq-Int Clk in my windows form written in Visual C++.
private: System::Void button1_Click(System::Objectsender, System::EventArgse) {
	private: System::Void button1_Click(System::Object^  sender, System::EventArgs^  e) {
				 int32       error=0;
				 TaskHandle  taskHandle=0;
				 char        errBuff[2048]={'\0'};
				 // DAQmx Configure Code
				 DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
				 DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
				 DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
				 DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(taskHandle,DAQmx_Val_Acquired_Into_Buffer,1000,0,EveryNCallback,NULL));
				 DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL));
				 // DAQmx Start Code
				 DAQmxErrChk (DAQmxStartTask(taskHandle));
	Error:
				 if( DAQmxFailed(error) )
					 DAQmxGetExtendedErrorInfo(errBuff,2048);
				 if( taskHandle!=0 ) {
					 // DAQmx Stop Code
					 DAQmxStopTask(taskHandle);
					 DAQmxClearTask(taskHandle);
					 MessageBox::Show("DAQmx Error");
			 int32 CVICALLBACK EveryNCallback(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples, void *callbackData)
				 int32       error=0;
				 static int  totalRead=0;
				 int32       read=0;
				 float64     data[1000];
				 // DAQmx Read Code
				 DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,1000,10.0,DAQmx_Val_GroupByScanNumber,data,1000,&read,NULL));
				 if( read>0 ) {
					 //printf("Acquired %d samples. Total %d\r",read,totalRead+=read);
					 fflush(stdout);
Error:
				 if( DAQmxFailed(error) ) {
					 // DAQmx Stop Code
				 return 0;
			 int32 CVICALLBACK DoneCallback(TaskHandle taskHandle, int32 status, void *callbackData)
				 int32   error=0;
				 // Check to see if an error stopped the task.
				 DAQmxErrChk (status);
Error:
				 return 0;
 Now, the methods
DAQmxRegisterEveryNSamplesEvent  and     DAQmxRegisterDoneEvent   must to be called as _cdecl  ..   so unmanaged code!
How can I call this methods in my windows form  (managed code) ?
(5,444 Views)
Here you can fing the entire project
https://github.com/Seio/GUIVS2012ReadDAQ
(5,421 Views)
