Measurement Studio for VC++
am looking for any example vi's for impact/modal analysis testing. I am
We are still working on a solution - when this is complete, we will post it here.
Message 11 of 28
(8,991 Views)
Doug
We seem to have lost contact on this problem - can we still work towards a solution?
Apart from upgrading elements such as number of channels, and other functions, the key step is to export the UFF files into MODENT. (NI generates UFF binary - MODENT needs UFF ASCII)
Is this possible?
I would welcome continue support on this.
Thanks for all your assistance so far.
Paul
Message 12 of 28
(8,970 Views)
no reply from contact at MODENT. I will investigate writing a conversion utility from the binary to ASCII version of UFF 58
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 13 of 28
(8,957 Views)
Here is the conversion utility. Please give it a try.
Doug
Message 14 of 28
(8,943 Views)
Here is a previously posted example program that implements a software trigger for impact test.
http://zone.ni.com/devzone/cda/epd/p/id/3438
The software trigger makes it so that the 9233, 9234, 4431, 4432, and other devices with no hardware analog level triggering can all be used for impact test.
Message Edited by dsb@NI on 02-10-2010 11:01 AM
Doug
Message 15 of 28
(8,941 Views)
The solution works now; allowing NI Labview to export data into UFF Binary, then convert UFF Binary into UFF ASCII, then read UFF ASCII into the MODENT Suite.
Thanks !
Message 16 of 28
(8,888 Views)
Here is a LV example that does Impact Test
Requirements: LabVIEW 8.2 Full or Pro, Sound and Vibration 2009, DAQmx 9.1
Feedback is welcome and appreciated!
Message Edited by dsb@NI on 05-19-2010 09:24 AM
Doug
Message 17 of 28
(8,399 Views)
Doug
Message 18 of 28
(8,395 Views)
above LLB was missing a typedef, and I also had a chance to fix a bug in limit test updates
By the way, if anybody has a chance to start using this, please comment on preferred behavior for saving and loading configuration. As an example, developers can always Make Current Value Default. If building an exe, would you expect a button 'Save Configuration', automatic saves, Prompt on Exit, All of these?
Message Edited by dsb@NI on 05-20-2010 11:35 AM
Doug
Message 19 of 28
(8,365 Views)
Hello Doug,
You've made a nice program, with a lot of practical features.
I've got only one problem: it doesn't save the measered data. The program does maken an empty result file...
An automatic save option would be excellent.
Thanks in advance!
Hans
Labview 2010
S & V 2010
Message 20 of 28
(7,191 Views)
