Measurement Studio for VC++
How to get Chassis serial number with system configuration C API?
I am able to get all of the hardware serial and alias information, but how do you specifically get the chassis itself?
(3,331 Views)
See this LabVIEW example using the same API and convert it to LabWindows/CVI functions.
Programmatically Read the Serial Number of a PXIe Chassis
https://forums.ni.com/t5/Example-Programs/Programmatically-Read-the-Serial-Number-of-a-PXIe-Chassis/...
LabVIEW VIs used are the following, you should be able to find the C API equivalents by searching NI System Configuration API Help.
Initialize
Create Filter
(Property Node) System Filter: Is Chassis
Find
(Property Node) System Hardware: Serial Number
Close
Close
Close
Here are the links I found on the property nodes:
Property Node (Filter) Descriptions
http://zone.ni.com/reference/en-XX/help/373107E-01/nisyscfg/property_node_filter/
Property Node (Hardware) Descriptions
http://zone.ni.com/reference/en-XX/help/373107E-01/nisyscfg/property_node_hardware/
(3,299 Views)
