Measurement Studio for VC++
Reply
How to get Chassis serial number with system configuration C API?
Highlighted
I am able to get all of the hardware serial and alias information, but how do you specifically get the chassis itself?
(726 Views)
Re: How to get Chassis serial number with system configuration C API?
See this LabVIEW example using the same API and convert it to LabWindows/CVI functions.
Programmatically Read the Serial Number of a PXIe Chassis
https://forums.ni.com/t5/Example-Programs/Programmatically-Read-the-Serial-Number-of-a-PXIe-Chassis/...
LabVIEW VIs used are the following, you should be able to find the C API equivalents by searching NI System Configuration API Help.
Initialize
Create Filter
(Property Node) System Filter: Is Chassis
Find
(Property Node) System Hardware: Serial Number
Close
Close
Close
Here are the links I found on the property nodes:
Property Node (Filter) Descriptions
http://zone.ni.com/reference/en-XX/help/373107E-01/nisyscfg/property_node_filter/
Property Node (Hardware) Descriptions
http://zone.ni.com/reference/en-XX/help/373107E-01/nisyscfg/property_node_hardware/
(694 Views)
