Measurement Studio for VB6
virtual pci card
I developed an application using a IMAQ PCI-1411 card. The card and
application is to be used in a different facility. I still need to support
this application, but would like to do it on my development PC (other
machine
is production machine - no development software). Can this be done, if so
how?
(3,177 Views)
No, there is currently not a way with our IMAQ drivers to simulate a board or remotely connect to it on another machine. You would have to have the board installed on your machine to run a program that accesses it.
What I would recommend is to use a #define flag to implement your program so it can run in simulation mode where you do not call functions to access the board. For example,
#define SIMULATION 1
#ifdef SIMULATION
//Do not connect to board, load simulated image
#elseif
//Connect to board and load image
#endif
That way, you can just comment out the #define statement when you want to run with hardware.
Best Regards,
Chris Matthews
(3,177 Views)
Sorry, I forgot this was Visual Basic. You would use a constant instead of a #define.
Chris
(3,177 Views)
