Measurement Studio for VB6
simultaneous read & write fast varying analog signal
Hello!
I am using USB 6008 Device to Read and Write analog signal.
I want to write analog output on channel exactly after each 10 millisecind and also read input on mutiple channel on each 10 millisecond.
I did code tested but cannot attempt time as I expected.
kindly help me !!!
(6,775 Views)
This can be done for analog input by acquiring in continuous mode at 100Hz (of course, aggregate not simultaneous), but for analog output, 600x supports up to 150S/s analog output rate with software time. Hence, its timing totally depends on how fast your PC run and it's not going to be precised. Hence, you need to change to USB-62xx or USB-63xx that supports hardware time analog output.
(6,287 Views)
