Measurement Studio for VB6
Data Read event in DAQmx with VB6
I don´t need to aquire data constantly, I only need one event. Each time I want to trigger an event I call the "acquiredata" routine.
You may try using infinite samples aquisition, or finite samples events it in a loop.
To be honest, i don´t really know why am i stopping the task, I don´t remember....
Thank you
Message 11 of 14
(3,882 Views)
Hello Olivier,
Have you tried the example located here:
C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Events\Every N Samples\Cont Acq-Int Clk-Every N Samples Event
This examples shows how to continuously acquire data using the Every N Samples event.
Eric
DE For Life!
Message 12 of 14
(3,874 Views)
thirst this example works in C but i am not able to do it working in VB6...
In a second time it doesn't do what i excpect. It produces the event but it reads the value in the event and i would like the event to return the result, the value of the  "n samples"
if you have an idea?!!
Thanx
Message 13 of 14
(3,872 Views)
Hello Olivier,
If you post your VB6 code, we can take a look at it and see why it isn't producing the behavior you are expecting!
Eric
DE For Life!
Message 14 of 14
(3,857 Views)
