Measurement Studio for VB6
CWAIPoint, CWDIO VB6 on windows 10
I have a project using vb6 running on win7 using the CWAIPoint and CWDIO
using the code example:
Option Explicit
Private Sub Form_Load()
    CWAIPoint1.Device = 1
    CWAIPoint1.channels(1).ChannelString = 0
End Sub
Public Function GetVoltageRead(Ch As Integer, Current As Double, Connected As Integer, Optional AvgN As Integer = 1) As Variant
Dim Measurement As Variant, I As Integer, MeanV As Single, Reading As Single
If Not No_NIDMM Then
    If AvgN <= 0 Then AvgN = 1
    Delay 0.15
    OutToPort Ch, Current, Connected
    Delay ReadDelay ' 0.35 '0.25 '0.2
    For I = 1 To AvgN
        CWAIPoint1.SingleRead Measurement
        Reading = Measurement
        MeanV = MeanV + Reading
    Next I
    V(Ch) = Val(Format(MeanV / AvgN, "###0.0###"))
    GetVoltageRead = V(Ch)
    ResetAddress
Else
    V(Ch) = Rnd * 1.5 + 1.8
    GetVoltageRead = Val(Format(V(Ch), "###0.0###"))
    Exit Function
End If
End Function
I have to rewrite the part of the code that using
CWAIPoint and CWDIO that use Read the Measurement on win10
That is possible? There is an example of that?
(5,908 Views)
Hello
What NI hardware you are using?
__________________________________________
The best way to thank, is to give KUDOS
(5,799 Views)
I have using https://documentation.help/NI-DMM-C.CVI.VB/ this method
and I have to replace  CWAIPoint, CWDIO components from
https://www.ni.com/en-il/support/documentation/supplemental/06/transition-from-traditional-ni-daq--l...
for example I have the next code :
Public Sub OutToPort(iCellNumber As Integer, sCurrentVal As Double, iA8 As Integer, Optional iA10 As Integer = -1)
    Dim iCurrentVal As Long, Apa_, Apb_, Bpa_, Bpb_, ICellNumber_ As Integer, C As Integer
    Dim Cab1 As Integer, On_%, Off_%
    If Lt = True Then
        On_% = iStateON%
        Off_% = iStateOFF%
    Else
        On_% = iStateOFF%
        Off_% = iStateON%
    End If
    If Not (Lt = True) Then iCurrentVal = mA2Bit(sCurrentVal, iCellNumber)
    If Lt = True Then iA8 = iA8 Xor 1
        If iCellNumber <= FirstCell + NFC / 2 - 1 Then
            Apa_ = APA '0
            Apb_ = APB '1
            Bpa_ = BPA '3
            Bpb_ = BPB '4
            ICellNumber_ = iCellNumber - FirstCell
        Else
            Apa_ = CPA '6
            Apb_ = CPB '7
            Bpa_ = DPA '9
            Bpb_ = DPB '10
            ICellNumber_ = iCellNumber - NFC / 2 - FirstCell
        End If
        If Lt = False Then
            Dmm.OutputBits.Ports.Item(Bpa_).SingleWrite iLowPart(iCurrentVal)
            Dmm.OutputBits.Ports.Item(Bpb_).SingleWrite iHighPart(iCurrentVal)
        End If
        Dmm.OutputBits.Ports.Item(Apa_).SingleWrite ICellNumber_                'aDDRESS=0
        Dmm.OutputBits.Ports.Item(Apb_).Lines(CellConnect).SingleWrite iA8
        Delay 0.05
        Dmm.OutputBits.Ports.Item(Apb_).Lines(cSync).SingleWrite Off_%
        If iA10 <> -1 Then
            Dmm.OutputBits.Ports.Item(Apb_).Lines(PowerRelay).SingleWrite iA10
        End If
    End If
End Sub
I have to replace by this methods  https://documentation.help/NI-DMM-C.CVI.VB/
the parts of  Dmm.OutputBits.Ports.Item(X) .....
 Dmm is a form that look like
https://prnt.sc/wc8cg3
(5,672 Views)
someone?
(5,615 Views)
I'm trying to install Visual Basic 6.0 Professional Edition in Windows 10 Home. I've run VB6 with Windows XP (SP3) for years with no problems. However, when I try to install VB6 in Windows 10, the installer stalls after a short time and becomes not responding.
(5,297 Views)
Two weeks ago i had the same issue installing VB6 on Win 10 Pro 64-Bit (setup.exe did not finish registering components).
In the net i found a tip which solved the problem:
Choose Custom Installation at the beginning und deselect Data Objects (including ADO, OLE, DAO).
I dont know why, but i think those runtimes are already part of the operating system and more up to date and cannot be overwritten on the fly.
After this i installed Service Pack 6. Then VB6.EXE need some Compatibility settings, so the IDE respons smoothly when moving custom controls on a form (XP SP3 compatibility mode or similar).
I am using VB6 still on Win 10 for several applications including Measurement Studio 8.6.11 applications.
For me it works.
(5,081 Views)
