10-20-2020 03:10 AM
I have a project using vb6 running on win7 using the CWAIPoint and CWDIO
using the code example:
Option Explicit
Private Sub Form_Load()
CWAIPoint1.Device = 1
CWAIPoint1.channels(1).ChannelString = 0
End Sub
Public Function GetVoltageRead(Ch As Integer, Current As Double, Connected As Integer, Optional AvgN As Integer = 1) As Variant
Dim Measurement As Variant, I As Integer, MeanV As Single, Reading As Single
If Not No_NIDMM Then
If AvgN <= 0 Then AvgN = 1
Delay 0.15
OutToPort Ch, Current, Connected
Delay ReadDelay ' 0.35 '0.25 '0.2
For I = 1 To AvgN
CWAIPoint1.SingleRead Measurement
Reading = Measurement
MeanV = MeanV + Reading
Next I
V(Ch) = Val(Format(MeanV / AvgN, "###0.0###"))
GetVoltageRead = V(Ch)
ResetAddress
Else
V(Ch) = Rnd * 1.5 + 1.8
GetVoltageRead = Val(Format(V(Ch), "###0.0###"))
Exit Function
End If
End Function
I have to rewrite the part of the code that using
CWAIPoint and CWDIO that use Read the Measurement on win10
That is possible? There is an example of that?
11-08-2020 01:20 PM
Hello
What NI hardware you are using?
12-29-2020 06:21 AM
I have using https://documentation.help/NI-DMM-C.CVI.VB/ this method
and I have to replace CWAIPoint, CWDIO components from
for example I have the next code :
Public Sub OutToPort(iCellNumber As Integer, sCurrentVal As Double, iA8 As Integer, Optional iA10 As Integer = -1)
Dim iCurrentVal As Long, Apa_, Apb_, Bpa_, Bpb_, ICellNumber_ As Integer, C As Integer
Dim Cab1 As Integer, On_%, Off_%
If Lt = True Then
On_% = iStateON%
Off_% = iStateOFF%
Else
On_% = iStateOFF%
Off_% = iStateON%
End If
If Not (Lt = True) Then iCurrentVal = mA2Bit(sCurrentVal, iCellNumber)
If Lt = True Then iA8 = iA8 Xor 1
If iCellNumber <= FirstCell + NFC / 2 - 1 Then
Apa_ = APA '0
Apb_ = APB '1
Bpa_ = BPA '3
Bpb_ = BPB '4
ICellNumber_ = iCellNumber - FirstCell
Else
Apa_ = CPA '6
Apb_ = CPB '7
Bpa_ = DPA '9
Bpb_ = DPB '10
ICellNumber_ = iCellNumber - NFC / 2 - FirstCell
End If
If Lt = False Then
Dmm.OutputBits.Ports.Item(Bpa_).SingleWrite iLowPart(iCurrentVal)
Dmm.OutputBits.Ports.Item(Bpb_).SingleWrite iHighPart(iCurrentVal)
End If
Dmm.OutputBits.Ports.Item(Apa_).SingleWrite ICellNumber_ 'aDDRESS=0
Dmm.OutputBits.Ports.Item(Apb_).Lines(CellConnect).SingleWrite iA8
Delay 0.05
Dmm.OutputBits.Ports.Item(Apb_).Lines(cSync).SingleWrite Off_%
If iA10 <> -1 Then
Dmm.OutputBits.Ports.Item(Apb_).Lines(PowerRelay).SingleWrite iA10
End If
End If
End Sub
I have to replace by this methods https://documentation.help/NI-DMM-C.CVI.VB/
the parts of Dmm.OutputBits.Ports.Item(X) .....
Dmm is a form that look like
01-10-2021 11:08 PM
someone?
06-28-2021 01:53 AM
I'm trying to install Visual Basic 6.0 Professional Edition in Windows 10 Home. I've run VB6 with Windows XP (SP3) for years with no problems. However, when I try to install VB6 in Windows 10, the installer stalls after a short time and becomes not responding.
10-23-2021 02:06 PM
Two weeks ago i had the same issue installing VB6 on Win 10 Pro 64-Bit (setup.exe did not finish registering components).
In the net i found a tip which solved the problem:
Choose Custom Installation at the beginning und deselect Data Objects (including ADO, OLE, DAO).
I dont know why, but i think those runtimes are already part of the operating system and more up to date and cannot be overwritten on the fly.
After this i installed Service Pack 6. Then VB6.EXE need some Compatibility settings, so the IDE respons smoothly when moving custom controls on a form (XP SP3 compatibility mode or similar).
I am using VB6 still on Win 10 for several applications including Measurement Studio 8.6.11 applications.
For me it works.
