wrap DAQmx .net Async funtions into an iobservable
What is the recommended way to wrap DAQmx .net Async funtions into an iobservable?"
(3,488 Views)
Shabnama,
 This is Ali from National Instrument's applications engineering.
Would you mean something like this?
http://zone.ni.com/reference/en-XX/help/370473H-01/mstudiowebhelp/html/asynchreadwritedaqnet/
Additionally, could you explain a little bit about the usage of this wrap DAQmx function, it would be good to have a little background to recommend references.
Ali S.
Applications Engineering
(3,458 Views)
Hi Ali,
Those are the available async functions in the NI API, we would like to have a wrapper around those functions to allow the consumption of the data through a Reactive Extensions (Rx) IObservable stream.
Shabnam
(3,455 Views)
Shabnama,
Sorry for the late reply. I was doing a bit of research on the Reactive Extensions (Rx) IObservable platform.
Is there a specific DAQmx function you would like to utilize?
For example, are you doing a Read DAQmx wrapper and then asking Reactive to pull data as needed?
Feel free to send in psuedo code or a specific DAQmx function or list of functions that you are trying to use?
Ali S.
(3,416 Views)
