how do I obtain UIMessages in .net without polling the engine
I need to obtain the UIMessages present in the engine without using the polling option.
Please tell me how it can be done
(3,715 Views)
Good Afternoon Akhalid,
It looks like we have a developer zone tutorial that tells how to set up UIMessage handling here: http://zone.ni.com/devzone/cda/tut/p/id/2898.
We also have some examples on how to work with UIMessages here: http://zone.ni.com/devzone/cda/epd/p/id/3879.
Please let me know if you have any further questions!
With warm regards,
David D.
(3,671 Views)
If I understand you want use event UIMessage :
First in InitializeComponent(), add this line :
 this.axApplicationMgr.UIMessageEvent += new NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_UIMessageEventEventHandler(this.axApplicationMgr_UIMessageEvent);
and then in your app add this Method :
 private void axApplicationMgr_UIMessageEvent(object sender, NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_UIMessageEventEvent e)
            // If new focus position is send
            if (e.uiMsg.Event == UIMessageCodes.UIMsg_UserMessageBase)
                if (e.uiMsg.NumericData == 1)
(3,661 Views)
