ZoomInOnPoint
Hello I am using NI MS 2015 with intensity graph and I am trying to utilize the ZoomInOnPoint method but it behaves very erratically. It does not zoom in as intended and in some cases it will zoom in but not in a smooth operation. Is there anything I should know with this method for the intensity graph to zoom smoothly?
(2,138 Views)
Could you provide a little more detail on the desired zoom behavior, compared to what the graph currently does? It would also be good to know how the graph is configured (e.g. the type of axes, and their settings). A sample application that reproduces the issue would be ideal to understand what is causing the zoom problem.
~ Paul H
(2,087 Views)
