08-02-2019 03:54 AM
For my next project I am thinking about using multiple cDAQ-9191 carriers with WiFi. It seems possible to create a virtual task in LabView and add multiple carriers. The syncing of the input signal is happening in the background.
However I dont use LabView and didnt find any documentation how to do this with the DAQmx lib in c#.
It would be really nice if someone could point me in the right direction.
Solved! Go to Solution.
08-12-2019 04:10 AM
Hello rizardus,
to begin with, synchronizing multiple 9191 chassis is not a trivial task irregardless of the programming language used. Please check out the answer in another thread:
https://forums.ni.com/t5/Multifunction-DAQ/Synchronize-multiple-9191-chassis/td-p/1900237
If you really need a real synchronization between the cDAQ chassis, I would recommend considering other models/different HW setup.
