Wpf graph with visual host RenderMode.Hardware error
graph rendermode= RenderMode.Hardware
debug error :
 System.Windows.Threading.Dispatcher.Run( );
The calling thread could not access this object because another thread owns the object.
(3,618 Views)
Accepted by jiewei_li
I was able to reproduce the problem and track it to a non-dispatched internal access to the application's main window, and have created a task to fix this.
We only perform this access once, so as a workaround you can force this initilaization to happen early (before starting the graph on the background thread) by adding this call to the main window's constructor:
    public MainWindow( ) {
        new NationalInstruments.Controls.Primitives.Tables.RenderTargetBitmapWrapper( 1.0, 1.0 );
        InitializeComponent( );
~ Paul H
(3,593 Views)
Just wanted to let you know this issue was fixed in the Measurement Studio 2019 release.
~ Paul H
(2,246 Views)
