08-27-2012 04:46 AM
Hello!
What I did, why I post my question:
1.) I started NI Teststand 2012 (in evaluation mode)
2.) I started the Demo => .NET => "computer.seq" example in the original Teststand examples folder
3.) I placed a breakpoint at the first Teststand step, started sequence "Single Pass" and
tried out Debug => "Step Into" as the Single Pass arrived at my Teststand breakpoint
4.) Visual Studio 2012 opened and I could step through the C- code
5.) Finishing debugging with "Continue" in Visual Studio and "Continue" in Teststand
6.) Teststand shows its report
Now I expect that the Teststand sequence has finished and I can change the C- code project / recompile
the Visual Studio project and Re-Run the Teststand sequence without closing and opening Teststand and
Visual Studio all the time
7.) *** BUT ***: Visual Studio is still in "Running" state:
I cannot recompile the C- code project, as the DLLs are still in use / read only.
Even Teststand's "File=> Unload all modules" does not help in this situation.
I would like to use Teststand/Visual Studio combination in this way - developing my C-code routines
I tried out more:
o) Closing Teststand releases the C- code project again and I can recompile it.
o) Running the Teststand sequence "Single Pass" without "Step Into" the C-Code in combination with
Teststands "File=> Unload all Modules" releases the C- code project and it can be recompiled
BUT: As soon as "Step Into" has been done once, the C- Code Project is blocked until I close Teststand
Can someone explain me this behavior and give me a hint how to release the C-Code Project,
so that it can be "rebuild" after the Teststand sequence run?
08-29-2012 04:23 AM - edited 08-29-2012 04:32 AM
Hello InVI_MaW,
How you can debug your Visual Studio Project into TestStand.
1. Open TestStand
2. Open the Visual Studio project
3. In Visual Studio under "Debug" attach your project manual to the SeqEdit.exe
4. Run your Sequence File in TestStand with a breakpoint on the position
you want to step into your Visual Studio Code
5. Step into the Visual Studio code
6. Continue Visual Studio
7. Run the TestStand sequence to the end
8. Under "File" in TestStand "Unload all Moduls"
9. In Visual Studio under "Debug" Detach the process
I hope this helps.
