Why can't I see classes in my C# dll ?
It seems like a stupid question which will have an obvious answer but I'm stuck so....
I am using Visual C# express 2008 to make my dll and would like to call my methods from TestStand 2012. I have taken the default Dotnet template, added the ref to the project and kept it deliberately simple for the purpose of this test; here it is:-
usingSystem;
usingSystem.Collections.Generic;
usingSystem.Linq;
usingSystem.Text;
usingNationalInstruments.TestStand.Interop.API;    // TestStand Core API.  Add <TestStand>\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.API.dll to your project as a reference.
usingSystem.Runtime.InteropServices;
namespace
TestStand_IF
classDummyClassName
publicvoid DummyFunctionName(SequenceContext seqContext, outString reportText, outbool errorOccurred, outint errorCode, outString errorMsg)
            reportText =
String.Empty;
            errorOccurred =
false;
            errorCode = 0;
            errorMsg =
String.Empty;
try
// INSERT YOUR SPECIFIC TEST CODE HERE
                reportText = "Success !";
// The following code shows how to access properties and variables via the TestStand API
// PropertyObject propertyObject = seqContext.AsPropertyObject();
// String lastUserName = propertyObject.GetValString("StationGlobals.TS.LastUserName", 0);
catch(COMException e)
                errorOccurred =
true;
                errorMsg = e.Message;
                errorCode = e.ErrorCode;
I add a "String Value" step in TestStand and alsign my dll but there is nothing to select in the root class box. I remember having similar problems maybe a decade ago in C - having to mark functions for export and checking that the type library was included but I don't think this is the case here.
(8,697 Views)
Accepted by topic author Georgey48
Try
Public DummyClassName
Curt
(8,680 Views)
As far as I know, you can't just call a method in a class in C#.
You need to create a new object of that class.
If you want to be able to create a method without first creating an object, you can make that method Shared.
(8,680 Views)
Thank you Curt,
I said It would be something obvious ;o)
(8,672 Views)
I had wondered about this myself. Why there is no constructor in the template but I guess, now that I can see the class, I can add constructor(s). I'll keep you all posted.
Thanks for your help
(8,670 Views)
All works fine, even without a constructor; don't know how but it does.
Thanks for everyones help..
(8,665 Views)
