Waveformgraph Stripchart appears shaking on PlotwaveformAppend with real time scrolling on X axis
I have a graph to show data on real time x axis. I wanted the graph to scroll from right to left and current time values (mm:ss) keep appearing on x axis. With the examples of Measurement studio, I succeeded in plotting the data in real time using strip chart. However, the grid is not smoothly scrolling it appears to be re-rendered and shaky. I tried changing the plotting speed or data feed speed  but still the result is same.  For comparison, please check CPU usage graph in Task Manager of windows. That kind of steady movement is expected in my graph. I have attached a video of my application to get an idea.
I found the exact problem reported in https://forums.ni.com/t5/Measurement-Studio-for-NET/Why-does-the-waveformgraph-in-stripchart-mode-re... but no solution.
Is there any way this problem can be fixed? Thanks a lot in advance.
Ashwini
Message 1 of 1
(1,549 Views)
